disable ip nat rule
disable ip nat rule rule_name
Description
Disables Network Address Translation (NAT) rules.
Syntax Description
ip Specifies Internet Protocol (IP).
nat Specifies NAT.
rule Specifies disabling a NAT rule.
rule_name Specifies the NAT rule to disable.
Default
N/A.
Usage Guidelines
You must disable a rule to make configuration changes to it.
The following example the disables the IP NAT rule "rule1":
# disables ip nat rule rule1
This command was first available in ExtremeXOS 31.2.
Platform Availability
This command is available on the switches that support the IP NAT feature. For information about which switches support this and other features, see the Switch Engine v33.1.1 Licensing Guide document.
